Why particle is not injected ?
Old   June 14, 2015, 06:38
Unhappy Why particle is not injected ?
YANNAPOL SRIPHUTKIAT
YANNAPOL is on a distinguished road
Dear All,
Normally, I use DPM and set the injection from inlet surface. It works well. Then, I try to use DPM-DEM by
1) Activate Eulerian Multiphase flow, set Dense Discrete Phase
2) In Discrete Phase, I activate the DEM collision under Physical Tab
3) I choose collision partner (anthracite-anthracite)
Problem
1) The particle is not injected ? I visualize by showing
1.1) particle variable > particle velocity
1.2) DPM concentration
(Attachment 1)
2) Sometimes it show fatal error
MPI Application rank 2 exit before finalize
(Attachment 2)
Anyone please kindly help, I am so desperate.
YANNAPOL is offline   Reply With Quote
dem, dpm, injection, multiphase, udf
temperature of injected particle aslaan.farjam@gmail.com FLUENT 0 December 1, 2014 14:09
Diameter of injected particle noa FLUENT 0 January 1, 2014 03:30
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Custom Drag using UDF for Injected Particle pmghadge Fluent UDF and Scheme Programming 0 May 15, 2009 17:00
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
