-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   (??) sinusoidal motion for DEFINE_CG_MOTION (http://www.cfd-online.com/Forums/fluent-udf/81821-sinusoidal-motion-define_cg_motion.html)
salzini November 8, 2010 03:34
I'm testing with a simple UDF for sinusoidal angular velocity motion but it has a problem.
macro [DEFINE_CG_MOTION] presents [omega] for angular velocity variable and [time] to passes time variable, so try this to describe a pseudo-vibrating cantilever.
omega is time dependant variable and displacement(angle) is intergation of the omega over the time passed. so I assumed if I put some intergand of the time into UDF, Fluent will reflect its integration to the moving boundary.
Few graphs were ploted for investigation
http://yfrog.com/51graphbj(http://yfrog.com/51graphbj)
and equations are...
w_1=sin(2*pi*t)
F_1 = INTEGRAL(w_1, t)
w_2=sin(2*pi*t + pi/2)
F_2 = INTEGRAL(w_2, t)
w_3=sin(2*pi*t - pi/2)
F_3 = INTEGRAL(w_3, t)
I choosed blue one(w_2) and its UDF code were...
DEFINE_CG_MOTION(move, dt, vel, omega, time, dtime)
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
omega[2]=sin(2*M_PI*time + M_PI/2);
my desired output was correct y position of lever though, it only moves over y=0 but y>0 and vise versa (no alternation of -+. just up and down under y=0 or over y=0).
I have no idea for [dtime] and [accumulater+= valiable] form to the that situation. So I put integrand in the UDF and hope the Fluent updates position of that intergrand for the time, but it seemed not that explictly :(
SO... It seems obiously there are stupid assumption or mis-understanding of UDF. Can I recieve a wise solution?
dmoroian December 10, 2010 05:47
First of all, I don't see why F_1 is always positive in your picture (http://yfrog.com/51graphbj).
If angular velocity is:
1. \omega = sin(2{\pi}t)
then the integral of it should be:
\theta = -\frac{1}{2\pi}cos(2{\pi}t)
which alternates between \left[-\frac{1}{2\pi};+\frac{1}{2\pi}\right]
2. \omega = sin(2{\pi}t+\frac{\pi}{2})
\theta = -\frac{1}{2\pi}cos(2{\pi}t+\frac{\pi}{2})
which again alternates between \left[-\frac{1}{2\pi};+\frac{1}{2\pi}\right]
My suggestion is to check around which origing you define this omega!
