(??) sinusoidal motion for DEFINE_CG_MOTION
Old   November 8, 2010, 02:34
Question (??) sinusoidal motion for DEFINE_CG_MOTION
ji-ho
salzini is on a distinguished road
I'm testing with a simple UDF for sinusoidal angular velocity motion but it has a problem.
macro [DEFINE_CG_MOTION] presents [omega] for angular velocity variable and [time] to passes time variable, so try this to describe a pseudo-vibrating cantilever.
omega is time dependant variable and displacement(angle) is intergation of the omega over the time passed. so I assumed if I put some intergand of the time into UDF, Fluent will reflect its integration to the moving boundary.
Few graphs were ploted for investigation
(http://yfrog.com/51graphbj)
and equations are...
w_1=sin(2*pi*t)
F_1 = INTEGRAL(w_1, t)
w_2=sin(2*pi*t + pi/2)
F_2 = INTEGRAL(w_2, t)
w_3=sin(2*pi*t - pi/2)
F_3 = INTEGRAL(w_3, t)
I choosed blue one(w_2) and its UDF code were...
DEFINE_CG_MOTION(move, dt, vel, omega, time, dtime)
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
omega[2]=sin(2*M_PI*time + M_PI/2);
my desired output was correct y position of lever though, it only moves over y=0 but y>0 and vise versa (no alternation of -+. just up and down under y=0 or over y=0).
I have no idea for [dtime] and [accumulater+= valiable] form to the that situation. So I put integrand in the UDF and hope the Fluent updates position of that intergrand for the time, but it seemed not that explictly
SO... It seems obiously there are stupid assumption or mis-understanding of UDF. Can I recieve a wise solution?
salzini is offline   Reply With Quote
Old   December 10, 2010, 04:47
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
First of all, I don't see why F_1 is always positive in your picture (http://yfrog.com/51graphbj).
If angular velocity is:
1. \omega = sin(2{\pi}t)
then the integral of it should be:
\theta = -\frac{1}{2\pi}cos(2{\pi}t)
which alternates between \left[-\frac{1}{2\pi};+\frac{1}{2\pi}\right]
2. \omega = sin(2{\pi}t+\frac{\pi}{2})
\theta = -\frac{1}{2\pi}cos(2{\pi}t+\frac{\pi}{2})
which again alternates between \left[-\frac{1}{2\pi};+\frac{1}{2\pi}\right]
My suggestion is to check around which origing you define this omega!
dmoroian is offline   Reply With Quote
define_cg_motion, sinusoidal, udf
UDF for non sinusoidal or varying amplitude motion with respect to time lalit kumar FLUENT 1 November 13, 2010 16:58
Sinusoidal motion udf urmazda Fluent UDF and Scheme Programming 6 July 30, 2010 11:44
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
tank motion on boat Tim FLUENT 0 May 23, 2007 11:50
Airfoil Sinusoidal Motion - How? Andrew FLUENT 1 April 8, 2005 19:42
