Particle-Source-In-cell (PSI-C) in DPM
Like Tree1Likes
  • 1 Post By gan6030
Old   November 8, 2010, 06:09
Question Particle-Source-In-cell (PSI-C) in DPM
john
johnwinter is on a distinguished road
Hi All,
Does any body knows how to get concentration of particles at required locations using DPM injection?
I am using Lagrangian particle tracking method. Any clues?
Thanks
John
johnwinter is offline   Reply With Quote
Old   November 10, 2010, 12:43
Allan Walsh
Allan Walsh is on a distinguished road
Do you mean to view the results of the concentration of the particle phase in Fluent? Or do you want to access the variable that contains the particle concentration in a macro? The variable for particle concentration will be described in the dpm.h header file and is called something like SV_DPMS_CONC... Good luck.
Allan Walsh is offline   Reply With Quote
Old   November 11, 2010, 00:10
john
Hi Walsh,
Thanks for your reply. I mean i want to monitor the DPM concentration at diferent locations in the domain. DO you have any idea can i do this using UDF?
Thanks
John
Old   January 31, 2011, 07:31
john
Hi Guys,
I am still stuck at this problem. Does anybody used PSI-C method UDF for DPM particle tracking. PSI-C method converts no. of particles in cell to the concentration of particles in the cell. Hnece, we can view/get particle concentration in the domain as like scalar in the domain.
Thanks in advance
Old   May 8, 2012, 23:36
godspeedwzw
just like wind is on a distinguished road
hi, have you solved the problem? I have the same problem, can we add the dpm concentration to the variable list? and how to use the PSI-C method? thanks!
just like wind is offline   Reply With Quote
Old   May 8, 2012, 23:41
godspeedwzw
I checked the manual and find if we select "interation with continuous phase", the dpm concentration with appear in the variable list. but how we add this to the list when we do one way coupling without selecting "interation with continuous phase"?
Old   October 21, 2012, 16:17
IVI
89566008 is on a distinguished road
I also want to display the contour of particle concentration.
how I can do this ?
89566008 is offline   Reply With Quote
Old   May 22, 2013, 14:52
gan6030 is on a distinguished road
I have managed to display the concentration contour in kg/m^3 after activating "interaction with continuous phase" , i want it to be in cfu/m^3, how can i do it?
Thanks in advance
asal likes this.
gan6030 is offline   Reply With Quote
Old   May 22, 2013, 15:00
mojtaba_a
mojtaba110 is on a distinguished road
Hi
as i understood, you have to solve it intransient. In DPM set you can mark the intransient solve . then you can track a particle.
Best Regards
mojtaba110 is offline   Reply With Quote
Old   September 7, 2013, 17:18
Astio Lamar
asal is on a distinguished road
@gan6030:
Could you please share your approach to explore contour plot of concentration ?
do you find any solution for CFU?
thanks
asal is offline   Reply With Quote
Old   April 11, 2016, 08:01
yun
gush is on a distinguished road
hi all
anyone succeeded to use PSI-C for concentration calculation in one-way coupling?
gush is offline   Reply With Quote
Old   June 23, 2018, 09:30
yun
can any one who needs it try the code below and share the comments if its working properly or not please?
ps. it needs to be compiled otherwise doesnt work!
#include "udf.h"
DEFINE_ON_DEMAND(Zero_UDM)
Domain *domain;
cell_t c;
Thread *t;
domain=Get_Domain(1);
thread_loop_c(t,domain)
begin_c_loop(c,t)
C_UDMI(c,t,0) = 0.0;
end_c_loop(c,t)
real dt;
DEFINE_DPM_SCALAR_UPDATE(Part_Con,c,t,initialize,p )
Set_User_Memory_Name(0,"UDM0: PSIC");
dt = (P_TIME(p) - P_TIME0(p));
C_UDMI(c,t,0) += P_FLOW_RATE(p)*dt/C_VOLUME(c,t);
Old   June 23, 2018, 18:36
obscureed is on a distinguished road
Hi Gush,
I've replied to the other copy of this post. (write UDF for the dpm model)
Ed
obscureed is offline   Reply With Quote
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 15:38
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
About Particle velocity of DPM in Fluent? long zhengwei FLUENT 0 March 13, 2009 05:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DPM particle tracks - speed up? Greg Perkins FLUENT 0 September 5, 2003 03:56
