Generating a file for each time step
Like Tree1Likes
  • 1 Post By blackmask
Old   July 21, 2013, 14:34
Default Generating a file for each time step
Raditya Wiranegara
radix is on a distinguished road
Hi Everyone,
I am working on a transient case and using a UDF with DEFINE_EXECUTE_AT_END macro. As I understand, the macro will execute the command or function at the end of each time step.
For my case,I want a file to be generated for each time step;i.e. let's say the file name is data.txt, I want the file to be data-(CURRENT_TIME).txt. Is it possible? Can anyone here help?
Thank you.
Radit
radix is offline   Reply With Quote
Old   July 21, 2013, 20:50
blackmask will become famous soon enough
char filename[100];
sprintf(filename, "data-(%.3f).txt", CURRENT_TIME);
radix likes this.
blackmask is offline   Reply With Quote
Old   July 21, 2013, 22:34
Raditya Wiranegara
Cheers! It helps a lot
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
