A problem about 'printf' and 'Message' in UDF.
I'm trying to write a UDF. But there is a tiny and boring problem now. To any UDF(whatever it is, even an example in Fluent UDF guidebook): 1. It CAN be compiled correctly. (with NO error & warning) 2. It CAN be hooked correctly. 3. It DOES work. (I tested this by changing the UDF code) BUT, whatever I used 'printf' or 'Message', it just CAN'T print any message in FLUENT console. I tested the UDF in other's computer, it worked and give the message in FLUENT console. I even copy that guy's DLL & LIB files to my machine to compile the UDF. It worked, but still can't print anything. It's really a tiny problem. But it is important for debugging. I'm so confused. Thanks a lot!! |
Hi~~It works!:D
I just reinstall the FLUENT and VC. Maybe there is something wrong before. But I still don't exactly know the reason. Anyway, thanks a lot and good luck! |
Thanks for sharing the answer.
