How to reset fluent with a command in a journal |
November 24, 2010, 08:43 |
Kike
Hello everyone.
I think that i have found what i need to solve my problem. I need one command that i can write on my journal to "clear" or "reset" fluent, like in gambit when you write reset, to clear all the information that fluent save from the first case automatically. Thanks for the help. |
November 24, 2010, 13:38 |
Kike
Anyone know how i'm saying?
When you run one case, fluent saves some dates, like viscous model, and also try to continue solving with the same values.. and finally an error appears. Anyone know what's the problem i talking about? Thanks! |
January 6, 2020, 13:58 |
#3 | |
mardar
Rep Power: 6 |
Could you find any command for resseting all settings in fluent? Best Regards |
January 7, 2020, 00:07 |
Alexander
Rep Power: 34 |
you may read mesh again
best regards ****************************** press LIKE if this message was helpful |
fluent 6.0, journal |
Fluent 12 Journal File Problem | Krish | FLUENT | 2 | July 16, 2010 06:10 |
running a journal file in Parallel FLUENT | novice | FLUENT | 0 | June 15, 2010 04:19 |
Re FLuent Journal | harry | FLUENT | 2 | May 12, 2010 01:03 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
On Bug of Fluent 12.0 | lzgwhy | FLUENT | 0 | August 26, 2009 06:41 |
