Define_profile
Old   January 19, 2011, 03:33
Default Define_profile
EH
ehooi is on a distinguished road
Does anyone know if such computations are allowed in DEFINE_PROFILE?
DEFINE_PROFILE(heater_bc,t,i)
#if !RP_HOST
if(I_AM_NODE_ZERO_P)
begin_c_loop(c,thtank)
C_CENTROID(coord,c,thtank);
x=sensor_coord[0];
y=sensor_coord[1];
z=sensor_coord[2];
if ((x >= xmin) && (x <= xmax))
if ((y >= ymin) && (y <= ymax))
if ((z >= zmin) && (z <= zmax))
Tpoint = Tpoint + C_T(c,thtank); /* get thermosensor temperature */
nt = nt + 1.0; /* count number */
end_c_loop(c,thtank)
Tpoint =Tpoint/nt; /* Average over all cells calculated */
compute_node_loop_not_zero(i)
PRF_CSEND_DOUBLE(i, &Tpoint, 1, myid);
IF (Tpoint < Tcutoff)
F_PROFILE = 1000
ELSE
F_PROFILE = 0
end
I have avoided all the variable declaration and some other syntax to shorten it. The reason I do not use DEFINE_ADJUST is because after calculating Tpoint, I don't know how to store it. I can write it as
begin_c_loop
C_UDMI=Tpoint
end_c_loop
but Tpoint actually doesnt belong to a particular cell. Other than the F_UDMI and C_UDMI, does anyone know how to pass the value calculated from DEFNE_ADJUST to DEFINE_PROFILE?
Thank you all.
Cheers
EH
ehooi is offline   Reply With Quote
