Home > Forums > Fluent UDF and Scheme Programming
UDF for moving mesh
Old   February 26, 2011, 05:00
Default UDF for moving mesh
Karthikeshwaran Ramasany
karthikeshwaran is on a distinguished road
hai,
am trying to write UDF in fluent for my rotor motion in the stator. I tried a lot but i cant can someone help me.....
Rotor having the both translation and rotational motion in stator.
the translation motion is in eccentric motion.
the eccentricity-4.039mm
The diameter of rotor is 39.878mm
stator dia-40.428
My rotor center linear motion is controlled by equation: x=2*e*sin(theta)
Where, eccentricity=e=4.078mm
Angle of rotor rotation =theta
Theta=w*t
Angular motion of rotor=Nr=60 rpm.
Angular velocity of rotor=w=2*Nr*pi/60 rad/s
Initially the rotor center (0,0) is same as stator center (0,0). I consider first plane of rotor (or stator) as the initial plane. As we move from one end (or initial plane) along z-direction, stator center lies on z-axis. But the rotor center moves eccentrically inside stator. [Stator is twisted and having its axis on z-axis].
Rotor pitch (Pr) =1/2*stator pitch (Ps) or Pr=Ps/2
Assume, Time step=dt
One rotor revolution takes 1/w seconds.
Time step=dt
Number of steps for a single revolution, N = (1/w)/dt
After time dt, the rotor center will be at x1=2e*sin(w*dt)
x1 is distance from the center (0,0).
http://www.youtube.com/watch?v=12Wszv1wUMk
In this link u can see the motion of rotor
karthikeshwaran is offline   Reply With Quote
Old   February 26, 2011, 08:47
Amir's Avatar
Amir
Amir is on a distinguished road
refer to:
Moving Wall Boundary Condition
Amir is offline   Reply With Quote
Old   February 27, 2011, 10:27
Default thanks
thanks a lot.........
Thread Tools
Trackbacks are On
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
Dynamic Mesh UDF Qureshi FLUENT 1 December 2, 2009 01:27
with UDF to change mesh by external mesh generator zou_mo FLUENT 0 June 30, 2009 07:15
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
