time dependent source using DEFINE_SOURCE
Old   March 16, 2009, 06:22
Default time dependent source using DEFINE_SOURCE
T81
T81 is on a distinguished road
Hi!
I'm doing a transient analysis is a 2D channel:
..............____________________________
heat --> |............................................ |
flux ---> |____________________________|
fluid ---> ----------------axis--------------------
I want to have a time dependent heat flux for the side walls (shown above).
I'm using the following code but I get the following error:
"chip-exec: qmax_source: wrong return type: void udf function expected"
I'm hooking the udf under Boundary Conditions --> Wall --> Heat Flux
What's wrong?
Thank you in advance.
/* UDF for specifying time dependent heat source */
#include "udf.h"
#define QMAX 156589
DEFINE_SOURCE(qmax_source,c,t,dS,eqn)
  real source;
  real time = CURRENT_TIME;
  if (time <= 100) /* time 0-100 q = QMAX */
      /* source term */
      source = QMAX;
      /* derivative of source term. */
      dS[eqn] = 0.;
  if (time > 100 && time < 200) /* time 100-200 q = 0 */
    source = dS[eqn] = 0.;
  if (time >= 200 && time < 300) /* time 200-300 q = QMAX */
      source = QMAX;
      dS[eqn] = 0.;
  if (time >= 300 && time <400) /* time 300 -400 q = 0 */
  else if (time >= 400)/* time 400- q = QMAX */
     source = QMAX;
     dS[eqn] = 0.;
  return source;
T81 is offline   Reply With Quote
Old   March 16, 2009, 06:55
Henrik Ström
HenrikS is on a distinguished road
This is not my area of expertise, but anyway... What the error message is saying is that you are using the wrong type of macro. It seems you cannot hook a DEFINE_SOURCE-macro to the BC->Wall->Heat Flux panel. I suggest you try writing a DEFINE_HEAT_FLUX-macro instead (see UDF manual chapter 2.3.8)? Hope this helps!
/Henrik
HenrikS is offline   Reply With Quote
Old   March 16, 2009, 07:38
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi T81,
Did you try to use DEFINE_HEAT_FLUX or DEFINE_PROFILE macros?
Dragos
dmoroian is offline   Reply With Quote
Old   March 16, 2009, 07:42
T81
Now I'm trying the DEFINE_PROFILE macro and its seems to work.
Thanks both of you for the replies.
Old   February 28, 2011, 13:16
lyes
lyes43 is on a distinguished road
Hello T 81 i'm a student I 'm working on simulate a turbulent flow in a rectangular channel were heat blocks are amounted using Fluent i had some problems need a help if u can hlp me write to me lyes43@yahoo.com
lyes43 is offline   Reply With Quote
Old   February 28, 2011, 17:23
T81
Hi lyes43,
I would be glad to help you (if I'm able to...) if you could describe your problem more specifically.
You can start a new thread for that, if this is not the appropriate thread.
Regards,
t81
define_source, time dependent
Time Dependent Temperature Dependent BC Analysis RP Main CFD Forum 1 March 28, 2008 01:22
Linearization of time dependent source variable CFDtoy Main CFD Forum 0 June 1, 2007 14:05
Time dependent Energy source Nitesh Main CFD Forum 0 July 17, 2006 13:19
time dependent energy source Nitesh FLUENT 0 July 17, 2006 13:14
time dependent source gbj FLUENT 1 April 9, 2005 08:06
