-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   Experience: Something about udf_names.c(7): error C2059 when compiling udf (http://www.cfd-online.com/Forums/fluent-udf/85760-experience-something-about-udf_names-c-7-error-c2059-when-compiling-udf.html)
chengdi March 6, 2011 12:53
Phenomena:
udf_names.c(7) : error C2059: syntax error : '}'
udf_names.c(8) : warning C4034: sizeof 0
Solution:
delete any whitespace character adjacent to the string "DEFINE_XXXX".
It should only be look like this:
DEFINE_XXX(p1,p2,p3)
and recompile.
Comment:
This error costs me 4 hours... :mad:
Actually I'd like to call it this error a bug which stems from the sentence below in the makefile:
@sed -n "s/^DEFINE_\([_A-Z]*\)( *\([_a-zA-Z0-9]*\).*)/\{\"\2\", (void (*)())\2, UDF_TYPE_\1\},/p" $(SOURCES) >> $@
I do not understand how it works. I think it is used to extract prototype information of the macro and write it to the udf_data[] array in udf_names.c file. However it cannot identify the MACRO with adjacent whitespace.
I hope someone good at makefile could make a patch on this. It must be very easy to professional coders.
Reference:
http://board.fluent.com/ubb/Forum2/HTML/000119.html
namankothari October 6, 2012 06:08
Hey Cheng,
Really your information was very helpful. It worked out !!!
Thanks
isabel January 7, 2014 17:07
Very good advice, thank you very much. I had written DEFINE_PROFILE (T, thread, position) instead DEFINE_PROFILE(T, thread, position)
rsarma July 10, 2014 12:58
Indeed a very good advice. Really appreciate such posts from people in such forums. Thank you.
blackmask July 10, 2014 21:11
[QUOTE=chengdi;298107]
If you want to allow any number of spaces between "DEFINE_XXX" and "(", then the "sed" command should be adapted to
sed -n "s/^DEFINE_\([_A-Z]*\) *( *\([_a-zA-Z0-9]*\).*)/\{\"\2\", (void (*)())\2, UDF_TYPE_\1\},/p"
marinagr September 26, 2014 14:32
Thank you so much for this information! It worked out fine for me!:)
toghay May 18, 2015 12:35
i love you chengdi
best regards
gaza January 25, 2016 10:09
thanks a lot for this post!
