User-defined Time Step
Old   March 9, 2011, 05:21
Default User-defined Time Step
saclu is on a distinguished road
Hi all,
I would like to define a user-defined time step with the DELTAT UDF
The UDF is defined this way:
DELTAT(name, d)
Domain *d: pointer to the domain over with the time stepping control fonction is to be applied.
I need my time step to be depend on the angular velocity of my body Cg which is in rotation. I can't get the angular velocity with the DT_OMEGA_CG(dt) beacuse dt isn't declared in DELTAT so I don't know how to do.
Does anyone would have an idea?
Thanks!
saclu is offline   Reply With Quote
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
