Flowfield temperature modification through UDF
Old   April 11, 2011, 04:27
Default Flowfield temperature modification through UDF
Robert
Hypersonicflow is on a distinguished road
I would like to introduce myself to this forum as quite a newbie when it comes to FLUENT UDFs.
I would kindy ask some of you to give me a clue how to:
Modify the temperature during the run in any cell (not just at the inlet).
Example: loop over all cells and if the velocity in a cell is larger than five, increase the temperature by one.
From the UDF manual, it is not really clear to me which command has to be used for this purpose. Is it DEFINE_ADJUST or any other comand?
Please excuse the simple nature of this question, but I would be really thankful for a short hint.
Robert
Hypersonicflow is offline   Reply With Quote
Old   April 11, 2011, 05:01
Amir's Avatar
Amir
Amir is on a distinguished road
Hi there,
you can use DEFINE_ADJUST here. in selecting define macros, you have to notice when and where it executes during iterations. this macro executes every iterations and you can make a loop over all cells so it's suitable.
regards,
Amir is offline   Reply With Quote
Old   April 18, 2011, 13:27
Smile Thanks
Robert
Thanks for your help, Armir - Problem solved.
Robert
UDF for a horizontal temperature profile CD Fluent UDF and Scheme Programming 9 May 6, 2018 12:13
UDF: temperature dependent BC ehooi FLUENT 6 January 22, 2011 12:26
Temperature calcul in UDF DEPRET FLUENT 1 May 7, 2008 04:34
ho to input a computed temperature value in a UDF mcb FLUENT 0 March 7, 2007 06:06
UDF modification merac FLUENT 4 March 1, 2001 06:42
