Timestep UDF not work
Old   April 28, 2011, 12:10
Default Timestep UDF not work
peaker007 is on a distinguished road
Hi,all
I have met a problem in timestep UDF.The following is my UDF code.
DEFINE_DELTAT(mytimestep,d)
real time_step;
real flow_time = CURRENT_TIME;
if (flow_time < 0.005)
time_step = 0.00005;
else if(flow_time < 0.025)
time_step = 0.0001;
else if(flow_time<0.175)
time_step=0.0005;
else if(flow_time<1.175)
time_step=0.001;
else if(flow_time<5.675)
time_step=0.003;
else if(flow_time<10.675)
time_step=0.005;
else
time_step=0.01;
return time_step;
After i hook my UDF to Fluent and start up the iteration,but only one time step can be run, then iteration was stopped and can not work continue.Who can help me to find out the reason.Thanks.
peaker007 is offline   Reply With Quote
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 06:43
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
udf - c++ compiler does not work Matthias FLUENT 1 January 9, 2009 00:44
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 10:55
Will the UDF work?? H.S.Fang FLUENT 0 December 27, 2001 21:21
