Defining a parameter for UDF
Old   April 14, 2011, 10:11
Default Defining a parameter for UDF
Philipp Schapotschnikow
Philipp_Sch is on a distinguished road
Hi all,
I have a UDF which requires a constant, real parameter. Is there a way to give this parameter a value, without having to modify and recompile the source?
Thanks,
Philipp
Philipp_Sch is offline   Reply With Quote
Old   April 14, 2011, 15:28
Amir's Avatar
Amir
Amir is on a distinguished road
refer to:
"Defining a Scheme Variable in the Text Interface" &
"Accessing a Scheme Variable in a UDF"
in UDF manual.
Amir is offline   Reply With Quote
Old   April 15, 2011, 03:56
Thanks a lot, Amir!!
Is there a way to check whether a variable (with the given name) has been defined in the TUI? The manual shows how to check this in TUI (which is already quite useful). But I would like to do the same in the UDF, something like
int myVar;
if(isDefined("variable-name")
myVar = RP_Get_Integer("variable-name");
else
myVar = DefaultValue;
Old   April 15, 2011, 10:55
Amir's Avatar
Amir
I'm not sure, but if you check whether the retrieved value in UDF is equal to NULL or not, may help you.
Old   April 15, 2011, 10:59
A call RP_Get_Real with an invalid scheme variable name produces a runtime error
Old   April 18, 2011, 21:23
gearboy is on a distinguished road
int myVar;
else
You can use "CX_Interpret_String" function to perform scheme command in UDF.
gearboy is offline   Reply With Quote
Old   April 19, 2011, 04:53
I use the following construction
int ret=0;
const int default_value;
ret = (int) CX_Interpret_String("( (if (rp-var-object 'var-name)) (%rpgetvar 'var-name))");
if(!ret)
ret = default_value;
return ret;
The UDF shows correct behaviour, but it returns error messages
Error : eval : unbound variable
Error object: %rpgetvar
These error messages make the execution extremely slow (but do not terminate it!). How can I avoid it?
I have no idea of scheme programming, can anyone suggest me how to write a line that does
" if variable "var_name" is defined, return 1, else return 0 "
Old   April 19, 2011, 21:28
int ret=0;
if(!ret)
return ret;
Just use:
CX_Interpret_String("(if (rp-var-object 'var-name) (rpgetvar 'var-name)(rpsetvar 'var-name default-value))");
ret=RP_Get_Integer("var-name");
Old   April 20, 2011, 04:35
Originally Posted by gearboy View Post
Just use:
This gives an error message because rpsetvar tries to set an undefined variable.
I also tried
CX_Interpret_String("(if (not (rp-var-object 'var-name))(rp-var-define 'var-name default-value 'integer #f))");
but it gives me an error "var-name" undefined variable.
I should also mention that I am using a compiled UDF.
Can it be that I need to include certain headers that are not present in udf.h?
Old   April 27, 2011, 21:19
I also tried
"default-value " is a representation of the default value of 'var-name, e.g. -1.
CX_Interpret_String("(if (not (rp-var-object 'var-name))(rp-var-define 'var-name -1 'integer #f))");
Old   May 2, 2011, 11:07
Yes, that's what I meant. In the actual code, I have something like
The error still occurs.
Old   May 2, 2011, 22:32
CX_Interpret_String("(if(not(rp-var-object 'var-name))(rp-var-define 'var-name -1 'integer #f)())");
Parameter Set Problem /Fluid Flow Paul_Re CFX 0 December 4, 2010 14:01
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
MAxium residual...confusion with expert parameter KK CFX 3 February 8, 2008 10:47
Expert Parameter for compressible transient ioannis CFX 0 November 2, 2005 19:28
parameter file CMB Siemens 1 December 15, 2003 09:01
