April 14, 2011, 10:11 |
Defining a parameter for UDF
Philipp Schapotschnikow
Rep Power: 15 |
Hi all,
I have a UDF which requires a constant, real parameter. Is there a way to give this parameter a value, without having to modify and recompile the source? Thanks, Philipp |
April 15, 2011, 03:56 |
Rep Power: 15 |
Thanks a lot, Amir!!
Is there a way to check whether a variable (with the given name) has been defined in the TUI? The manual shows how to check this in TUI (which is already quite useful). But I would like to do the same in the UDF, something like int myVar; ... if(isDefined("variable-name") myVar = RP_Get_Integer("variable-name"); else myVar = DefaultValue; |
April 15, 2011, 10:59 |
Rep Power: 15 |
A call RP_Get_Real with an invalid scheme variable name produces a runtime error
April 18, 2011, 21:23 |
#6 | |
Rep Power: 17 |
April 19, 2011, 04:53 |
Rep Power: 15 |
I use the following construction
int ret=0; const int default_value; ... ret = (int) CX_Interpret_String("( (if (rp-var-object 'var-name)) (%rpgetvar 'var-name))"); if(!ret) ret = default_value; return ret; The UDF shows correct behaviour, but it returns error messages Error : eval : unbound variable Error object: %rpgetvar These error messages make the execution extremely slow (but do not terminate it!). How can I avoid it? I have no idea of scheme programming, can anyone suggest me how to write a line that does " if variable "var_name" is defined, return 1, else return 0 " |
April 19, 2011, 21:28 |
#8 | |
Rep Power: 17 |
CX_Interpret_String("(if (rp-var-object 'var-name) (rpgetvar 'var-name)(rpsetvar 'var-name default-value))"); ret=RP_Get_Integer("var-name"); |
April 20, 2011, 04:35 |
#9 | |
Rep Power: 15 |
I also tried CX_Interpret_String("(if (not (rp-var-object 'var-name))(rp-var-define 'var-name default-value 'integer #f))"); ret=RP_Get_Integer("var-name"); but it gives me an error "var-name" undefined variable. I should also mention that I am using a compiled UDF. Can it be that I need to include certain headers that are not present in udf.h? |
April 27, 2011, 21:19 |
#10 | |
Rep Power: 17 |
CX_Interpret_String("(if (not (rp-var-object 'var-name))(rp-var-define 'var-name -1 'integer #f))"); ret=RP_Get_Integer("var-name"); |
May 2, 2011, 11:07 |
#11 | |
Rep Power: 15 |
Yes, that's what I meant. In the actual code, I have something like CX_Interpret_String("(if (not (rp-var-object 'var-name))(rp-var-define 'var-name -1 'integer #f))"); The error still occurs. |
May 2, 2011, 22:32 |
#12 |
Rep Power: 17 |
CX_Interpret_String("(if(not(rp-var-object 'var-name))(rp-var-define 'var-name -1 'integer #f)())");
Parameter Set Problem /Fluid Flow | Paul_Re | CFX | 0 | December 4, 2010 14:01 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
MAxium residual...confusion with expert parameter | KK | CFX | 3 | February 8, 2008 10:47 |
Expert Parameter for compressible transient | ioannis | CFX | 0 | November 2, 2005 19:28 |
parameter file | CMB | Siemens | 1 | December 15, 2003 09:01 |
