May 19, 2011, 09:33 |
Error in opening UDF library
Disabled
I am trying to load my UDf library.It's working fine while building the library.I am experiencing the below error while trying to load the library
Opening UDF library Error open_UDF_library:The system cannot find the file specified ================================================== = The source file contains 3 header files in addition to udf.h only 1 one of them exists in 'src' folder.. please help .......... |
May 19, 2011, 15:43 |
alighaffari
Please explain more. Are you using windows or Linux platform? What are your header files? I think your system have not compiled your UDF properly.
May 20, 2011, 13:00 |
Disabled
Dear ali,
I'm using windows 7 professional(64 bit) platform. My headers are: #include "udf.h" /* must be at the beginning of every UDF */ #include "sg.h" /* must be at the beginning of this UDF */ #include "math.h" /* must be at the beginning of this UDF */ #include "Slip.h" /* must be at the beginning of this UDF */ thanks for the kind answer. Best Regards |
May 20, 2011, 15:28 |
alighaffari
I think your problem is related to compiling your UDF not to your header files. For confidence in this matter I suggest you first try to compile a simple example UDF code and use TUI method instead of GUI to compile UDFs certainly.Then if there are any problems yet look at this thread in this URL it will be helpful.
http://www.cfd-online.com/Forums/fluent/44201-attn-all-soluton-udf-compile-problem.html |
May 21, 2011, 02:10 |
Disabled
Thanks,I'm gonna try it!
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
error open udf library | adjie_mesin06 | Main CFD Forum | 1 | October 27, 2010 01:49 |
fluent UDF external library lapack problem | Rick | FLUENT | 0 | May 7, 2008 10:16 |
Error in opening the UDF library | Sri | FLUENT | 3 | December 11, 2006 16:19 |
