April 19, 2014, 03:46 |
udf for mass transfer
sarighulikhan
Rep Power: 12 |
i need to wright a udf for mass transfer(diffusion)
phenol is diffusing from oil to water through interface would you guide me in this regard? i mean which macro should i use? is it possible to write udf for this? is there any ready example availabe for this? it is very urgent , i would be thankful if u..... thanks & regards |
April 19, 2014, 13:40 |
#2 | |
Mahesh
Rep Power: 12 |
I am not very sure as i am also new to write UDF. You may try DEFINE_MASS_TRANSFER functions. You need to write your diffusion equation for mass transfer in codes. You may look for some other help as i am also a beginner in UDF.
Good Luck...... Quote:
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
UDF for hear transfer coefficient in non-thermal equilibrium porous meda | sheeko | Fluent UDF and Scheme Programming | 8 | January 1, 2020 23:43 |
UDF to change heat transfer coefficient | eng_yasser_2020 | Fluent UDF and Scheme Programming | 1 | July 1, 2016 09:47 |
Mass transfer UDF expecting void return | Quinos | Fluent UDF and Scheme Programming | 0 | January 8, 2014 18:36 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
