June 8, 2011, 20:25 |
Please check out my UDF code
Rep Power: 15 |
Hi! I want to model a filter (but not modeling it as a porous media), in a room I have SO2 and air mixture. First I want to get the SO2 mass flow rate at the inlet surface of the filter, then multiply it by 0.999989, and set the sink rate of the filter volume as -0.999989*(SO2 mass flow rate at the inlet surface)/(Volume of filter). For the outlet of the filter, I set it as "interior", and my simulation is always transient.
Below is my code, please advise. #include "udf.h" DEFINE_SOURCE(cell_SO2mass_source,cell,thread,dS,e qn) { real x[ND_ND]; real source, t, massflowrate, volume, vol_tot; real ti = RP_Get_Real("flow-time"); real NV_VEC(flux), NV_VEC(A); /* declaring vectors flux and A */ face_t face, f Cell_t cell Thread *thread C_CENTROID(x,cell,thread); x=x[0]; /*****给出每个单元的x坐标*******/ y=x[1]; /*****给出每个单元的y坐标*******/ z=x[2]; /*****给出每个单元的z坐标*******/ d = Get_Domain(1); t= Lookup_Thread(d, 12); /* defining the inlet surface thread by specifying the Zone_ID*/ begin_f_loop(f,t) { NV_D(flux, =, F_U(f,t), F_V(f,t), F_W(f,t)); /* defining flux in terms of velocity field */ NV_S(flux, *=, F_R(f,t)) /* multiplying density to get flux vector */ F_AREA(A,f,t) /* face normal vector returned from F_AREA */ massflowrate+= F_YI(f,t,i)*NV_DOT(flux,A); /* dot product of the inlet surface flux and area vector*/ /* multiplied by the mass fraction of species i */ } end_f_loop(f,t) massflowrate= PRF_GRSUM1(massflowrate); begin_c_loop(cell,thread) { volume = C_VOLUME(cell,thread); /* get cell volume */ vol_tot += volume; } end_c_loop(cell,thread) vol_tot = PRF_GRSUM1(vol_tot); source=-0.999989* massflowrate/vol_tot; dS[eqn]=0.0; return source; } I actually have 2 question: 1. is "f" the inlet surface corresponding to the "t" that I set? "t" is the thread corresponding to inlet surface. 2. is C_CENTROID necessary in this case? 3. someone says "cell_t cell" is wrong, only "cell_t c" is correct, but why? Thanks Last edited by aleisia; June 9, 2011 at 00:18. |
June 9, 2011, 02:10 |
john
Rep Power: 15 |
I may not fully answer you. From your udf i understood that you don't need x[ND_ND], you didn't use it anywhere in the code. So don't define it. i fell C_CENTROID not necessary. cell_t cell is there you can use it but DEFINE_SOURCE already calling all cells. So, don't define cell_t at all. Yes, you are calling inlet face "f". |
June 9, 2011, 13:34 |
#3 | |
Rep Power: 15 |
Hi! Thanks for the reply and I agree with you.
How about Thread *thread? I guess I don't need to define thread either, because I already called it in the DEFINE_SOURCE How about the way that I defined the mass flow rate, using dot product? Is that OK? or I can use F_FLUX*F_AREA*F_YI? Quote:
June 10, 2011, 04:02 |
john
Rep Power: 15 |
Yes, you don't need to define thread also.
It seems to me that massflowrate+= F_YI(f,t,i)*NV_DOT(flux,A); is ok. |
Convergence check in UDF | mittal | Fluent UDF and Scheme Programming | 0 | January 22, 2011 22:21 |
Request for UDF code for forced vibrations | jagadeesh putta | FLUENT | 0 | November 21, 2007 21:43 |
Check UDF | stephen e | FLUENT | 1 | April 15, 2004 09:51 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 12:40 |
