June 8, 2011, 13:25 |
mixture model or multiphase model in my UDF?
Rep Power: 15 |
Hi!
I'm trying to model a filter without using porous medium: In a 3D model with air and another gaseous substance (say, SO2) as a mixture, there is a volume, I want to get the mass flow rate of the mixture at one inlet surface of the volume, and reduce it to 1% of the inlet value, and set this new value as the boundary condition at the outlet surface of the volume, then set the SO2 mass flow rate difference between inlet and outlet surface as the sink rate of the volume. In order to do that, I have some questions: 1. Both air and SO2 are gaseous, so I can use mixture mode, instead of Euler multiphase model, right? 2. Using mixture model, do I have to use the utilities looping over phase domains in a mixture? I mean, they are both at the same gaseous phase, there is no phase interface, right? If so, how do I get the info of SO2 and air mass flow rate at the inlet surface? 3. Can I use F_PROFILE(f,t,n) n is used to specify SO2 or air, instead of writing sub_domain_loop, am I getting this right? Thanks! |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
How to decide interfacial length scale in Mixture Model of CFX multiphase simulation? | TommySean | CFX | 6 | April 6, 2012 23:46 |
udf for multiphase flow with real gas mixture | sugumaran | ANSYS | 0 | July 30, 2010 11:38 |
air and water vapour mixture - multiphase model | Saba | FLUENT | 0 | February 10, 2009 12:05 |
Multiphase Mixture Model fluent5.4 | Julia Kullmann | FLUENT | 0 | March 9, 2001 05:13 |
