changing a variable (turbulence dissipation rate) formolation
Hi
I must modify eps (C_D) in one part of my work. I simulating a slurry bubble column and I have to modify my turbulence dissipation rate by this formula: eps(modify)=eps(original)*exp(A*alpha) eps(modify):turbulence dissipation rate that I need to use in my calculations eps(original): turbulence dissipation rate that fluent calculates A: constant alpha: volume fraction of particles and I need to change eps to these formula just in my population balance aggregation and breakage kernels. can I do this with a udf? which macro I must use? I know that I can wrote the kernels in udf and hook them to populaton balance model but I want to just change the eps it is more easily and I can use the original code of fluent that have less problems thank you |
with a simple DEFINE_ADJUST macro, store modified epsilon in a UDM and then use it where ever you want. |
Hi
Thank you amir but I am new in writing UFD, an I have an other question. I want to change eps just in one of fluent parts, and I don't want to write a udf for whole part. you see: for example in population balance model I choose lou aggregation equations that is avalable in fluent just by using population balance model and choose lou kernel for it from a drop down list. but I want to send my eps(modify)" that I wrote the equation of that on the last post" instead of eps(original) to the part of lou equations. I know how to save the my eps(modify) in a UDM, after that how I can send it to the lou equations instead of eps(original) ( that I think using the C_D macro for that in the fluent ) in other word, I want to change or modify one of the fluent equations, is this possible? or I must write whole part of the equation again in a UDF? excuse me for my poor English |
I haven't used this model before and I don't know about its characteristics, but I have some suggestions: - first look for capability of hooking any UDF in your desired model description. - I think it would be possible to change C_D for using in this eq. and then retrieving previous value (because I don't know about this model, I'm not sure about) - If you can interpret this model as a conservation eq., then you can use UDS template of FLUENT instead. (again I'm not sure about its nature) Amir |
modified dissipation term in k-w SST
Hello all,
I want to modify the dissipation term of k-equation by UDF. Which macro can be used? Actually, I must change the formulation of dissipation term in k-equation and then, Fluent uses the modified dissipation term instead of itselfs. My turbulence model is k-w SST and I just manipulate Y_k (dissipation term of k). Original: Y_k=ro*beta_s*k*w; Modified: Y_k=ro*beta_s*k*w/delta; (delta is wall distance) It would be appriciated if anyone makes a comment to how I do this task. |
Did you find a solution to this problem that you had? Quote:
You need to use source macro to modify production and dissipation terms in any turbulence models. Quote:
