UDFs and Time dependence.vs.Velocity
Old   February 23, 2011, 08:27
Smile UDFs and Time dependence.vs.Velocity
ThanhToan
trantoan2008 is on a distinguished road
Send a message via Yahoo to trantoan2008 Send a message via Skype™ to trantoan2008
Hi all,
Actually, I need to help from everybody. I am facing one problem in UDFs of Fluent software. Because velocity at inlet condition varies time function as shown in attached firgure, I still did not described this function by using UDFs in Fluent.
Actually, I can describe time function by data which stored in file (format **.txt), and put this data in my code. However, I did not know how to defined time solution when it running.
Anybody help me to solve this problem?
Thanks so much.
trantoan2008 is offline   Reply With Quote
Old   March 1, 2011, 18:32
Real Name :)
ComputerGuy is on a distinguished road
If you send me the data or post it here, I'll try and get a UDF that will work.
ComputerGuy is offline   Reply With Quote
Old   March 1, 2011, 22:32
ThanhToan
Hi Man,
I hope you can help me to make UDF code for this problem. According to your message, I send data to you.
Thanks in advanced.
Tran
Old   August 1, 2011, 12:47
NeNaD
skinnyfluid is on a distinguished road
Originally Posted by trantoan2008 View Post
Hi all,
Thanks so much.
Hi trantoan2008,
Did you solve your time series problem (velocity varies with time)? I am dealing with the same problem. Have you any udf for this problem?
Thank you in advance,
NV
skinnyfluid is offline   Reply With Quote
multiple UDFs at the same time bharti FLUENT 0 November 2, 2006 10:45
UDF Working At The Same Time Carlos V. FLUENT 0 March 21, 2006 11:30
How many UDFs can I specify at the same time? Ynot FLUENT 2 March 8, 2006 19:19
Multiple UDFs Graeme FLUENT 4 August 28, 2004 15:47
how to define two UDFs at the same time in a model welch FLUENT 1 May 8, 2004 21:01
