-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   Accelerating pre and checking the mfr at exit how to hook udf to Pressure inlet(BC) (http://www.cfd-online.com/Forums/fluent-udf/91628-accelerating-pre-checking-mfr-exit-how-hook-udf-pressure-inlet-bc.html)
kokoory August 17, 2011 08:20
hello, guys.
I have a problem to apply udf to my model.
the problem is analysizing very small nozzle.
However, I have no idea to code and apply udf.
first, I used a pressure inlet to vary a total pressure from 0 to 10Mpa using udf.
It's good to check and analysis the nozzle. But, in addition, I have to apply checking a mass flow rate at nozzle exit. after checking the mass flow rate, I should apply a volumetric heat addition as per mass flow rate( mass flow rate * mdot Q).
here is the question.
1. I hooked the below code, however, I think it is not working. I wanna do change the pressure from 2Mpa to 10Mpa and check the mass flow rate at the exit simultaneously.
plz help me..
Please see the attach
#include "udf.h"
face_t f;
cell_t c;
DEFINE_EXECUTE_AT_END(mass)
Domain *d;
real flow=0;
real p=0;
Thread *t;
d = Get_Domain(1);
t= Lookup_Thread(d, 7);
begin_f_loop(f,t)
flow+=F_FLUX(f,t);
end_f_loop(f,t)
p = C_P(c,t);
printf("MASS Flow Rate: %g\n",flow);
DEFINE_PROFILE(pre, t, i)
real pressure_mag;
real cu_tim;
//face_t f;
cu_tim = CURRENT_TIME;
if((cu_tim>=0)&&(cu_tim<10))
pressure_mag=202650+101325*cu_tim;
else
pressure_mag=1013250;
begin_f_loop(f,t)
F_PROFILE(f,t,i) = pressure_mag;
end_f_loop(f,t)
