problem with udf
hello,
pls help i am trying to vary the inlet velocity profile for which i have made a following udf #include "udf.h" DEFINE_PROFILE(variable_velocity,t,i) { real x[ND_ND]; real y; face_t f; begin_f_loop(f,t) { F_CENTROID(x,f,t); y=x[1]; F_PROFILE(f,t,i)=7.36+0.368*y; } end_f_loop(f,t) } but the problem with it is that it is giving a constant velocity at the inlet that is 7.36. I think that probably it is not taking the coordinate into the equation. pls help me. its urgent |
Did you check your units? Also, is your inlet parallel to Y-axis or X?
Just suggestions though. I don't know about your case file. |
yes i checked the unit, but don't know what effect will the inlet direction would make on the udf. although it is parallel to x axis
Your profile varies with y and not x. Hence, the result will be a constant on the inlet when the inlet is aligned to the x-direction. Interchange the x and y coordinates.
thank u for ur reply
i tried with interchanging x & y, but still i am getting constant velocity |
when i try to read the mesh with scaling in M units, it is showing the variation, but when i try to read the file in mm units its showing constant velocity. why it is show
when i try to read the mesh with scaling in M units, it is showing the variation, but when i try to read the file in mm units its showing constant velocity. why it is so. pls help me i am new to fluent
hi,
it is a dupplicated thread! if you have a function 7.36+0.368*y and the variation of y is about 10 mm then the variation of velocity would be about 0.0037 and you may think a constant velocity is set in inlet. but if the variation of y is about 10 m then variation of velocity would be about 0.3 and you will see a linear velocity profile in inlet easily. just think about that ;) yours, mohammad |
thank you for ur answer. i am obliged
