September 20, 2011, 19:33 |
vaporization pressure UDF
Rep Power: 14 |
Hello to everyone!
I'm a new member here and have a problem, which I hope some of you will help me to solve. I'm trying to compile an UDF function with which I would be able to define changing of vaporization pressure in cavitation. As it is written in UDF manual, you have to use DEFINE_PROPERTY udf. So I wrote the udf and compiled it. The problem is that when I want to select this UDF in vaporization pressure dialog box I get the message: error: No user-defined functions have been loaded. Up to now, I've written a couple of UDF-s for compressible water, its sound speed and so on, and all of these have worked well. This one however, doesnt. I have searched the forum and on the internet for the solution of my problem, but without luck. If you know what might be the solution, please let me know. regards Komon |
UDF to adjust pressure outlet | a.lynchy | FLUENT | 4 | February 15, 2021 00:50 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
calculation average pressure in a plane with UDF | Vitalij | FLUENT | 1 | April 10, 2007 03:39 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
pressure extrapolation on C(vof, udf) | sunjong | FLUENT | 0 | October 16, 2003 23:13 |
