Home > Forums > Fluent UDF and Scheme Programming
Parallel
Old   September 28, 2011, 22:28
Default Parallel
Jack cosby
3DmaniacSLDWRKS is on a distinguished road
Can someone please tell me if it is NECESSARY to parallelize UDF codes if you are using a cluster to run your case??
My problem is that my case and UDF code run flawlessly on my desktop but as soon as I run the case on our computing center everything falls apart and I get very bad results.
Thanks
Any input is appreciated.
3DmaniacSLDWRKS is offline   Reply With Quote
Old   September 29, 2011, 15:59
Mohammad
m2montazari is on a distinguished road
hi,
it depends. do you compile your udf or interpret it? does it return any errors when reading the case on cluster or when reading C file? what is the DEFINE macro you used?
make the problem more clear.
yours,
mohammad
m2montazari is offline   Reply With Quote
Old   September 29, 2011, 18:39
Jack cosby
Thanks for the quick response,
No I dont have any problems reading the case and data files or the UDFs, but the results that I get are totally different( AND WRONG) from what I get on my desktop (WHICH ARE MOST DEFINITELY CORRECT).
macros that I use include execute at end, CG-motion, define-geometry, define-profile.
Can you explain to me what exactly you mean when you say it depends?
Thanks.
Thread Tools
Trackbacks are On
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
Cumulative continuity error large in parallel simulations xiao OpenFOAM 3 March 7, 2011 04:13
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
