UDF error
Hi all,
I interpreted the below udf file in Fluent. I got parse error during interpreting. cpp -I"C:\Fluent.Inc\fluent6.3.26/src" -I"C:\Fluent.Inc\fluent6.3.26/cortex/src" -I"C:\Fluent.Inc\fluent6.3.26/client/src" -I"C:\Fluent.Inc\fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "E:\Gambit\1106VIV01\motion.c" Error: E:\Gambit\1106VIV01\motion.c: line 3: parse error. I could not find what is wrong with udf file. Please leave any comments on this problem. #include "udf.h" static real v_prev = 0.0; DEFINE_CG_MOTION(osc,dt,vel,omega,time,dtime) { Thread *t; Domain *d = Get_Domain(1); real x_cg[3], force[3], moment[3]; real accl, dv; real mass = 0.2; real wn = 12.0; real k= mass * wn*wn; real c = 2*mass*wn*0.00; int i; NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); t = DT_THREAD(dt); for(i=0;i<3;i++) x_cg[i]=DT_CG(dt)[i]; Compute_Force_And_Moment(d, t, x_cg, force, moment, TRUE); force[1] += -k*x_cg[1] - c*vel[1]; accl = force[1]/mass; dv = accl*dtime; v_prev+=dv; vel[1] = v_prev; printf("Computed force: %g \n", force[1]); printf("Velocity: %g\n", vel[1]); } |
hi,
as the error says, the problem is with line 3. and in the udf you've post, definition of v_prev is the problem. try normal real(not static) definition. maybe fluent has some problems with static parameters!? then try renaming v_prev to vprev. all the things that could make problem is these two! nothing else.... yours, mohammad |
You cannot interpret such UDFs even if you will solve error (line 3). You have to compile it. Bests, |
hi,
I agree with amir. |
Thank you guys.
