UDF parallel error: chip-exec: function not found?????
Old   August 12, 2009, 18:48
Default UDF parallel error: chip-exec: function not found?????
Prashanth
shankara.2 is on a distinguished road
Hi all
I'm using a DEFINE_DPM_BC UDF on a wall in my domain. It's been running fine on serial for my previous cases. Even for parallel, I used the #if !RP_HOST and #endif commands within my UDF and it worked fine. I'm using the same UDF for a new case now.
When I run in parallel, I get the msg "Error:chip-exec: function 'none' not found'. I used some print statements inside my UDF to see if the UDF is getting executed but from what I see, FLUENT doesn't even go inside the UDF and none of the statements are printed. I'm guessing it's a problem with my parallel case. When I run the UDF in serial, it does get executed and I can see FLUENT passing through various stages of my UDF through the printed messages but after a while, I get the message 'Fluent process could not be started'.
What might be the problem here? I'm pretty sure nothing has changed in my system setup from when I ran my UDF successfully for my previous cases.
I did do something different but am not sure how much of an impact this will have on my UDF running correctly. Before I solved my flow field, I broke down the wall where the UDF will be applied into two. I used the Adapt-> Iso-value->Grid->Radial coordinate to mark some cells within a certain area on the wall and then used Separate->Faces to separate the wall into two regions and then solved my flow field. Now, the UDF is applied only to one region on my wall and I have reflect BC set on the other region. Not sure how much of a difference this will make.
Thanks
Prashanth
shankara.2 is offline   Reply With Quote
Old   January 16, 2012, 22:14
A.Brusly Solomon
brusly is on a distinguished road
hi
Are you using UDMI in your UDF? If you are using UDMI,Please set User defined memory.
brusly is offline   Reply With Quote
Parallel UDF problem Lindsay FLUENT 4 June 20, 2016 09:37
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 09:48
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
UDF in Parallel Gavin FLUENT 1 June 19, 2005 22:17
