fprint problem
Old   June 4, 2010, 14:38
Default fprint problem
MASOUD
MASOUD is on a distinguished road
Hi folks,
Believe or not, I'm struggling with fprint command!
I wanna see some defined parameters value in the console while the iteration is going on.
Here is my one of my UDFs for energy source term:
#include "udf.h"
#include "mem.h"
static real ACT_AREA_C=300000;
static real REF_EXCH_CURR_C=0.40;
static real REV_POT=1.02;
static real MW_O2=0.032;
static real MW_CO2=0.044;
static real MW_MIX;
static real X_O2;
static real X_CO2;
static real ALPHA_A=1.5;
static real ALPHA_C=0.5;
static real NO_ELEC=2;
static real FARADAY=96485;
static real UNI_GAS_CONS=8.314;
static real STOCH=-0.5;
static real RXN_RATE_C;
static real Z;
static real ZZ;
static real ZZZ;
static real ELEC_COND=1300;
static real CARB_COND=140;
static real OVERPOT_C;
static real SOURCE_1;
static real SOURCE_2;
static real SOURCE_3;
static real SOURCE_4;
static real SOURCE;
static real A;
static real B;
static real J_S;
static real J_L;
DEFINE_SOURCE(ENERGY_SOURCE_CATHODE,c,t,dS,eqn)
A=NV_MAG(C_UDSI_G(c,t,0));
B=NV_MAG(C_UDSI_G(c,t,1));
J_S=A*ELEC_COND;
J_L=B*CARB_COND;
SOURCE_1=pow(J_S,2)/ELEC_COND;
SOURCE_2=pow(J_L,2)/CARB_COND;
MW_MIX=MW_O2*C_YI(c,t,1)+MW_CO2*C_YI(c,t,2);
X_O2=C_YI(c,t,1)*MW_O2/MW_MIX;
X_CO2=C_YI(c,t,2)*MW_CO2/MW_MIX;
Z=ACT_AREA_C*REF_EXCH_CURR_C*pow(X_O2,0.375)*pow(X _CO2,(-1.25));
ZZ=exp((ALPHA_A*FARADAY*(C_UDSI(c,t,0)-C_UDSI(c,t,1)-REV_POT))/(UNI_GAS_CONS*C_T(c,t)));
ZZZ=exp(-(ALPHA_C*FARADAY*(C_UDSI(c,t,0)-C_UDSI(c,t,1)-REV_POT))/(UNI_GAS_CONS*C_T(c,t)));
RXN_RATE_C=Z*(ZZ-ZZZ);
OVERPOT_C=C_UDSI(c,t,0)-C_UDSI(c,t,1)-REV_POT;
SOURCE_3=RXN_RATE_C*OVERPOT_C;
printf("Z= %d\n", Z);
printf("ZZ= %d\n", ZZ);
printf("ZZZ= %d\n", ZZZ);
printf("RXN_RATE_C= %d\n", RXN_RATE_C);
printf("J_L= %d\n", J_L);
printf("J_S= %d\n", J_S);
printf("SOURCE_1= %d\n", SOURCE_1);
printf("SOURCE_2= %d\n", SOURCE_2);
printf("SOURCE_3= %d\n", SOURCE_3);
printf("SOURCE_4= %d\n", SOURCE_4);
SOURCE_4=0;
SOURCE=(SOURCE_1+SOURCE_2+SOURCE_3+SOURCE_4);
dS[eqn]=0;
return SOURCE;
The problem is: I can't see these parameters value in the console, nothing.
Please help me out.
Masoud
MASOUD is offline   Reply With Quote
Old   June 4, 2010, 19:14
DoHander is on a distinguished road
First be sure that your UDF is loaded and is running in Fluent (it is hooked to a model), then you can try to use Message instead of printf, Message is Fluent's own replacement for printf.
Do
DoHander is offline   Reply With Quote
Old   June 4, 2010, 23:23
MASOUD
Many thanks Do;
But it's not resolved though! Any special header like #include < stdio.h> needed?
Masoud
Old   June 5, 2010, 23:10
You can try to include stdio.h
Do
Old   October 28, 2011, 13:46
Nathan
natantyt is on a distinguished road
Hi
did you find any answer to the "printf" problem?, I want to see some values on the console and it does not show up. Thank You!
natantyt is offline   Reply With Quote
Old   October 30, 2011, 16:08
MASOUD
Not for fprint, 'Message' worked well though.
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
