-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   udf compilation problems since upgrading (http://www.cfd-online.com/Forums/fluent-udf/94169-udf-compilation-problems-since-upgrading.html)
orland November 8, 2011 04:42
I've recently switched from Fluent 6.3 to 13
when i try to run a udf fluent returns the following:
fatal error C1083: Cannot open include file: 'stdio.h': Invalid argument
can anyone help?
Amir November 8, 2011 08:46
Are you sure that VC++ is linked to this version?
Is this header necessary for your UDF?
orland November 8, 2011 08:48
if VC++ wasn't linked, wouldn't i get a "nmake is not recognized" sort of message?
Amir November 8, 2011 09:12
Because you're using newer version, maybe there is a problem in setting environment variables; to check this, use VC++ command prompt and launch FLUENT.... (before that delete previous environment variables of previous FLUENT version if there is any) ... can you compile other UDFs?
Also check whether you really need this header or not.
Bests,
