-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   Pls help UDF about particle size (Rosin-Rammler) (http://www.cfd-online.com/Forums/fluent-udf/94635-pls-help-udf-about-particle-size-rosin-rammler.html)
ch3coohminh November 21, 2011 17:50
Hi every body
I have a code about particle size distribution (Rosin-Ramsler)
D = d_tb. (-ln(1- Y ))^(1/n)
PHP Code:
#include "udf.h"
#include "math.h"
DEFINE_PROPERTY(particle_dia,cell,thread
real n=3//size distribution constant
real d_tb=0.0000040//d_tb is the mean particle size
real d// particle diameter
real y
real v;
real e=2.71828182845904523536;
real temp1,temp2;
real dens;
C_VOLUME(cell,thread);  // get info about volume of cell
dens C_R(cell,thread); //get ifo about density of cell
y=v*dens//caculate mass fraction of cell
temp1=(log(-(1-y)))/log(e);
temp2=exp ((1/n)*log(temp1));
d=d_tb*temp2;
   return
d;
but when i run this code
Error: This is a post-processing only executable.
Error Object: #f
please help me or give a suggest
ghost82 November 22, 2011 04:18
Why don't you use the built-in fluent Rosin-Rammler capability?You can specify this distribution without a special udf.
Daniele
ch3coohminh November 23, 2011 06:15
Daniele
thanks ghost82 for suggest.Can you tell me more details about using built in ROSIN RAMMLER distribution ?
I have not found other way specify this distribution without udf.
thank again so much.
ghost82 November 25, 2011 04:23
Sure!
You have to use the dpm (discrete phase model); for example for a steady state simulation, first you solve your problem without the dpm; after you reach the solution, you can enable the dpm model (in the same window where you define turbulence/laminar model, energy equation, etc.); after you enable the dpm, you have to set the max number of time steps (this could be changed if after the particles tracking you have an important amount of "incomplete" particles - incomplete means that particles are still in your domain); you have to define injection(s) of particles (click on injections..) and there you can chose to inject a single, a group, or a surface etc. of particles; you define the type of particles (for example inert), and in the same window you will see the possibility to change the diameter of particles from "constant" to "Rosin-Rammler" or to "Rosin-Rammler-logaritmic".
If you choose Rosin-Rammler you have to input some parameters, based on your particle distribution: see here for the how calculate these parameters:
https://www.sharcnet.ca/Software/Fluent12/html/ug/node692.htm
You may want to enable the stochastic tracking and write the number of stochastic tries: for example, if you set the number of stochastic tries to 2 this means that 2 particles will be tracked in their possible paths, starting from the same point.
You can also choose if your particles interact with the continuous phase or not and after how many iteration the particles interact.
After you define the injection you have to modify the particle material in the material panel.
Then you can modify boundary condition: for example you can set the wall to reflect the particles, and the outlet to let escape the particles.
At the end, to view the particle path you have to set in the graphics and animation window the particle track, choose the release injection point/surface and wait for the result.
Hope this help,
Daniele
chmurillor December 20, 2011 00:46
Varying PSD
Hi guys
Do you know any UDF to vary the particle size distribution? I have already included a DPM model and have a solid particles dispersion in air. I want to consider collisions to aggregate and fragment particles during dispersion.
Thanks for suggestions
Carlos
ch3coohminh December 23, 2011 22:36
Originally Posted by chmurillor (Post 336398)
Hi guys
Carlos
hi
Please tell more details .
chmurillor December 24, 2011 12:44
The UDF should consider the velocity and position of the particle and the velocity and stresses of the fluid near the particles.
I'd like to know how to invoke these parameters.
Thanks in advance
Best regards
Carlos
ch3coohminh December 28, 2011 11:09
Thanks in advance
Best regards
Carlos
please contact me by email ch3coohminh@gmail.com
We will disscus about this problem.
Minh Van Nguyen
souria January 22, 2016 10:47
Hey, I know its an old post.
Is anyone can tell me how to introduce a log-normal distribution or a modified Rosin-Rammler in Fluent. Because I had adjusted the distribution law to my own experimental data and I get a modified Rosin-Rammler (and or a log-Normal) which correspond exactly to my data.
Thanks for help
Souria
