Time step UDF for help
The CFD calculation is so time-consuming, so I want to define the timestep size by udf, and then expect that the calculation can be done automatically, i.e, after a certain steps, timestep size can be changed and go on calculating without taking care manually. I have used the following UDF, but when used it in practice, it does not work well. After calculate for 100 steps, the iteration will stop, then I have to restart the calculate, but it stopped after another 100 steps. Plese help me, thanks in advance.
DEFINE_DELTAT(my_timestep,d) { real time_step; real flow_time = CURRENT_TIME; if (flow_time < 0.005) time_step = 0.00005; /*0.00005 100 steps */ else if(flow_time < 0.025) time_step = 0.0001; /*0.0001 200 steps */ else if(flow_time<0.175) time_step=0.0005; /*0.0005 300 steps */ else if(flow_time<1.175) time_step=0.001; /*0.001 1000 steps */ else if(flow_time<5.675) time_step=0.003; /*0.003 1500 steps */ else if(flow_time<10.675) time_step=0.005; /*0.005 1000 steps */ else time_step=0.01; return time_step; } |
What do you choose for the "Number of Time Steps" under "Run Calculation" ?
you must put a number higher than 4600 (total number of steps) |
