Particle tracking without "Particle interaction with continuous phase"
Hello all,
I wonder, if I can track particles without any fluid field interactions and any other interactions in Fluent. Just like the particle was in vacuum and no fields would participate. I have done some experiments, no fluid field was calculated and Particle Interaction With Continuous phase was disabled + initial mass + starting velocity. Particle material - Antracite diam. about 9.3e-08m, mass 5e-22kg, density 1kg/m3, starting velocity 100m/s. Apparently, the particle starts from the defined point but slows down markedly after very short time- tens of interations (1e-10s time step size). If there is no filed and no other interactions, the particle should continue on its journey, or am I wrong? this behaviour would explain only presence of drag force of a gas defined by the drag force term still active and 0m/s velocity of the gas, so then there would be a strong damping effect... Does anybody know how to turn off all the forces acting on the particle?:confused: Regards, Peter |
