udf problem
hi all;
Please I have a problem in the numerical simulations made by Fluent 6.3 and Ansys Fluent 12.0.16 even when I use the UDF. it is interpretable but when I put the UDF in the interaction window or in the properties of materials such as for example the viscosity between the two phase fluent displays this message: Error: FLUENT Received fatal signal (ACCESS_VIOLATION) 1. Note exact events Leading to error. 2. Save case / data Under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () knowing that I work with the VOF model. I would be very grateful if you help me solve my problem of simulation. cordially |
Rubis,
Usually this happens when you're: a) trying to access something that fluent isn't calculating (i.e. temperature in a simulation without the energy equation enabled) b) performing a calculation which "blows up" (divide by zero, NaN errors, etc) If you post your code, perhaps we can figure it out. ComputerGuy |
Thank you for help .
i will do it best reagards |
