parallel running issue
Old   January 18, 2012, 17:42
Wink parallel running issue
xiaokang
xiaokang is on a distinguished road
Dear all,
I compiled a parallel udf and work very well in local PC.
When I ran it in cluster with parallel mode, it claimed a lot of warns at the first time. Then i built and load udf again in cluster(the warns still claimed).And then i read the same case for the second try, nothing claim~~everything seems ok!
So, is that ok? I heard if you run your case in parallel, you must make your "build path" as a "absolute path", or you must put your udf into every node your case use....... All of that I didn't do, but just build udf again and read case again, seems everything goes well! I really worry about there do have some error but just no claim to me.
ps, I use fluent13 version.
Great thanks!
xkyan
xiaokang is offline   Reply With Quote
udf parallel
OF 2.0.1 parallel running problems moser_r OpenFOAM Running, Solving & CFD 9 July 27, 2022 03:15
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
parallel running - error while loading shared libraries: seami OpenFOAM Installation 1 December 9, 2011 04:39
Running PimpleDyMFoam in parallel paul b OpenFOAM Running, Solving & CFD 8 April 20, 2011 05:21
Running dieselFoam in parallel. Palminchi OpenFOAM 0 February 17, 2010 04:00
