March 1, 2012, 09:27 |
Airfoil Pitching
#1 | |
sheth roh
Rep Power: 14 |
I am performing airfoil Pitching in fluent. The pitching is simple harmonic and is about the centroid. From diagram you can see that pitcing is about z axis. Here is my udf Quote:
Can you tell whats wrong with code. ? Note: I only set dynamic mesh zone in airfoil(So DO I need to set other zones too?) I have tried setting 6 DOF on and off but in both case it doesnt work. |
March 9, 2012, 09:26 |
Airfoil Pitching Problem
Saif Ullah
Rep Power: 14 |
You should add following commands to the udf. Don't use omega[2] simply. I hope it will work. Set only your airfoil as dynamic zone and give CG absolute coordinates in creating dynamic zones. You airfoil should start rotating about that point.
daft = (60 * (pi/180)) * 2*pi*0.2 * sin(2*pi*0.2 * time); alpha = 60 * cos(2*pi*0.2 * time); /* set omega */ omega[2] = daft; Regards |
March 11, 2012, 02:17 |
#3 | |
sheth roh
Rep Power: 14 |
I will definitely try this code. Meanwhile can you please tell me if the following setting are correct for dynamic mesh: - I am giving motion via define_cg_motion - I set moving zone only to the airfoil, I consider it rigid and provide motion via udf. SO DO I NEED TO SET OUTER REGION AS DEFORMING - I set only smoothing and remshing not layering. - Also when I use prism mesh around airfoil, it always gives negative volume. SO for such mesh what settings should be made. I really appreciate your help. Regards |
Display Modes | |
Pitching Airfoil in FLUENT | salihovic | FLUENT | 2 | October 24, 2013 13:58 |
Airfoil pitching problem | montag dp | FLUENT | 12 | June 25, 2012 06:25 |
How to realize pitching airfoil with drooping nose calcualtion? | zeitistgeld | CFX | 1 | July 27, 2010 07:17 |
UDF for pitching airfoil | Abu Bakar | Main CFD Forum | 0 | March 18, 2007 04:29 |
quasi steady analysis of 2d airfoil (pitching) | Alex | FLUENT | 1 | February 10, 2006 02:54 |
