udf initalizing problem
#include "udf.h"
DEFINE_PROPERTY(cell_viscosity, c,t) { double u, uo, A, B, C, T; //uo, A, B, C are constant uo = 4.485e-8; A = -7.5907e-7; B = 3.8968e-4; C = 4.0130e-2; for (T=1; T<101; T++) { u = uo*(exp(1/((A*T*T)+(B*T)+C))); printf ("T = %3.0f, u= %3.8f \n", T, u); } return u; } this is my programme to simulate heat transfer considering variable viscosity, the programme can be interpreted but when i initalize it goes into an infinte loop, need suggestions and help. thanks in advance |
First of all, the loop counter T should be defined as integer and not as real. Don't know how your compiler handles this exactly but fix it anyway.
Secondly DEFINE_PROPERTY macros are called for each cell every iteration. That means your udf will loop 100 times for each cell which may take a long time if your mesh is big. cheers |
