UDF for inlet BC, Free Surface Open Channel Flow VOF
Like Tree5Likes
  • 1 Post By arshiya4
  • 2 Post By ghost82
  • 2 Post By arshiya4
Old   February 20, 2012, 05:39
Default UDF for inlet BC, Free Surface Open Channel Flow VOF
Arshiya Hoseyni Chime
arshiya4 is on a distinguished road
Hi everyone
I am working on an open channel flow problem. I used the VOF model and successfully simulated a free surface flow over a bump! But, I figured that Fluent assigns a velocity to both water and air! However, I want to set the inlet velocity of air to zero.
My advisor wants me to write a UDF to set a parabolic velocity for water flow from bottom to free surface and then set air velocity on top to zero! This is the UDF I came up with but it doesn't work! (0,0) is the left bottom corner of a rectangle (0.1x0.6 m) . Free surface is at 0.05m and has 2m/s velocity.
#include "udf.h"
#define Ui 2.0
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f,thread)
F_CENTROID(x, f, thread);
y=x[1];
if (y<0.05.)
F_PROFILE(f, thread, position)= Ui*(y*y)/(0.05*0.05);
else
F_PROFILE(f,thread, position)=0;
end_f_loop(f,thread);
I will appreciate any help
Best regards
Arshiya
nahid rahnama likes this.
arshiya4 is offline   Reply With Quote
Old   February 20, 2012, 07:02
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi!
Delete the point after 0.05 and include the if cycle into the begin_f_loop and your udf will be fine.
Here is the corrected udf:
#include "udf.h"
#define Ui 2.0
real x[ND_ND];
real y;
face_t f;
y=x[1];
if (y<0.05)
else
..and attached your resulting inlet x velocity after some iterations.
Daniele
rajann_786 and nahid rahnama like this.
ghost82 is offline   Reply With Quote
Old   February 20, 2012, 21:51
Thank you Danielle. It worked
Old   March 6, 2012, 18:13
Question problem encountered with UDF
I used the UDF in a simple channel flow with the following Boundary Conditions:
My shape is 0.6x0.15 m
Inlet:
- Velocity: UDF (max velocity gets to 1.2m/s at free surface)
- Free surface level: 0.07m
Outlet:
-Free Surface: Use from neighboring cell
Sides of the rectangular: no slip
The idea of writing this UDF is to set the velocity of air to zero and give a parabolic velocity for water inlet. But, once I run the Fluent, velocity profile shows that velocity of mixture is about zero on the bottom and about 7.5 m/s for air! Also Velocity vectors imply that air moves faster than water! Although, I set air Temperature to zero at the inlet!!!!
I've attached my velocity profile, velocity vector, and defined profile.
I would appreciate any help.
Arshiya
File Type: jpg parabolic velocity_interpolated data.jpg (42.4 KB, 83 views)
remo and nahid rahnama like this.
free surface, open channel flow, udf, vof
Thermocapillary free surface flow zakifoam OpenFOAM Running, Solving & CFD 10 December 12, 2016 11:44
Open channel flow motaba Main CFD Forum 4 March 26, 2011 03:22
Open Channel Flow forsumit FLUENT 0 October 1, 2009 02:01
Free surface, open channel Linda FLUENT 2 April 10, 2006 11:43
open channel flow vof model Yong Siemens 3 June 21, 2005 05:54
