Home > Forums > FLUENT
Insert wall without changing mesh ???
Old   April 19, 2012, 04:55
Question Insert wall without changing mesh ???
Zigainer is on a distinguished road
is it possible to insert a wall in fluent without changing the mesh?
Basically I have a plenum and I want to split this plenum into two plenums.
Is there any possibilty to do that without a new mesh (therefoe I have to change geometry first and then mesh again ...)
Thanks in advance.
Zigainer is offline   Reply With Quote
Old   April 19, 2012, 10:43
dengjiajia
dunga82 is on a distinguished road
Hi, dear Zigainer, if you just want to compare the results without split and with split, and you have know where is the wall. I suggest you make the wall split first and then make the mesh, if you want to simulate one plenum, just define the split wall as interior. And if you want to simulate two or more plenums, define the split walls as wall.
You can change the boundary condition inside fluent and not need to change geometry and mesh. But what you need get note is that suggest change the boundary in serial fluent and not in parallel fluent.
Any question please feel free let me know.
Thanks.
dunga82 is offline   Reply With Quote
Old   April 19, 2012, 10:49
Hi dunga82,
thanks for your reply. What you suggest is fine, but I am at the point that I only have one plenum right now and I wqant to spilt taht one, withoiu meshing again ..... When I saw my results there was a big vertex in the plenum and one idea would be to split the plenum and see if we get two smaller vertexes ....
But any way, I guess there is no option to add a wall to my existing mesh right now ???
Old   April 20, 2012, 10:07
dengjiajia
Originally Posted by Zigainer View Post
Hi dunga82,
according to your problem, that you need to define the position of split on the results of one plenum. That is to say you need to change the geo and mesh.
but I think that is not so difficultly to do so.
Old   April 23, 2012, 07:53
Thanks!
It is indeed not too much work, but just create a plane in fluent and define this as wall would be much more easier ;-)
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 24 June 27, 2016 08:54
[ANSYS Meshing] refining mesh near wall icemaniac178 ANSYS Meshing & Geometry 1 June 1, 2016 02:48
Fluent converting 'wall' to 'interior' BC for hybrid mesh DarrenC FLUENT 6 November 6, 2014 06:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
slow after mesh for enhanced wall treat DPM joshkemp FLUENT 0 May 1, 2007 17:20
