April 19, 2012, 09:09 |
Rotational periodic boundary condition
Helen
Rep Power: 14 |
Hello.
How do you think if I model the flow inside such two domains as: 1) the whole domain (360 degrees), containing, for example, 20 rotational periodic repeated parts 2) the domain (18 degrees), which is the sector 1/20 of the domain 1, using the rotational periodic boundary condition will the results identical??? I'll be thankful for yours comments PS. Sorry for my english |
April 19, 2012, 09:44 |
#2 | |
Lucky
Rep Power: 65 |
The answer is not always. It will depend on the flow. It is definitely worth a shot to try it on the reduced domain though. Do you expect the flow in all 20 parts to be exactly the same? If yes, then yes you can model 1/20. If no, then do the full 20/20. An instability may arise in one or more of the parts and move through the domain, use of periodic boundary conditions would otherwise kill these structures. |
April 19, 2012, 10:49 |
Helen
Rep Power: 14 |
Thank you.
All 20 parts of the domain are the same, so I modeled 1/20 part using periodic boundary condition. But satisfying my interest I modeled whole domain (360 degrees) and I got the periodic flow field, but this flow field is differ from the 1/20. But I thought that results will be similar ... |
April 19, 2012, 10:56 |
#4 | |
Lucky
Rep Power: 65 |
If you are doing steady RANS, they should be identical. |
April 19, 2012, 11:47 |
Helen
Rep Power: 14 |
I think the same way. But I don't know how to explain my results. (((
periodic boundary condition in LES | martor | FLUENT | 3 | April 30, 2022 00:20 |
periodic boundary condition (translational) fluent 6.3 | haihek | FLUENT | 3 | January 22, 2014 04:10 |
Calculation of pressure gradient in periodic boundary condition | ksaat | FLUENT | 7 | May 16, 2011 03:59 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
translational periodic boundary condition | Rola Afify | FLUENT | 2 | September 12, 2006 08:39 |
