about choosing Turbulence model for multiphase flow problem.
hi everybody,
i need your help, i am now dealing with a multiphase flow problem (gas-assisted injection molding, as the pic show, i just focus on "the second step") by vof. Seems that the gas phase and the air phase (white in the pic(second step)) are Turbulence flows(Re>6000), and the melting plastic phase(black in the pic, second step))is laminar flow (Re<1). so,the melting plastic was set as laminar flow(By udf), and the Turbulence model was choosen as k-e, SST, Re Stress. But, all these simulation was no so match with experiment result--the wall thickness was much smaller than that of experiment result. you got any advise? PS:i am not so good at the parmetres-setting thing. http://www.jeco-tech.com/en/upImgFil...2221219673.jpg |
1) The role that turbulence plays is at best debatable for this problem. I think it is better to use 0D or 1D calculations and not rely on CFD. You can probably choose any turbulence model (including laminar) and get very close to the correct result. 2) injection molding is a well known non-Newtonian flow. Throw on top of it a solidification front and CFD will not like that. Again, I think simple 0D and 1D calculations are more appropriate, and probably more accurate for this problem. |
# 1) you've got a very good understanding about this problem, to find out the role that turbulence plays is the most critical and difficult thing . # 2) the non-Newtonian flow phase was set by UDF (the same model as Moldflow (a software only for injection simulation)...).."solidification front" thing maybe just the answer to the difference between my simulation and experiment. 1) about the solidification front, do you got advise in FLUENT(any alternative solution?) 2) or other SOFTWARE is ok~ |
I do not have any experience with VOF. With multiphase however, I've helped someone with a solidification/melting problem for a phase-change heat exchanger / heat storage device. The results were great, but that was for a stationary front. I highly recommend sticking to pure injection molding solvers. I've worked with some that are great. You mentioned MoldFlow, the SolidWorks cad package has an injection molding software. I-DEAS also has injection molding support (I-DEAS is now Unigraphics NX). If you are trying to focus on the turbulence then you should focus on just the gas injection process and throw away everything else. I seriously doubt turbulence would have any effect since you are just pumping gas into a flexible tank. Anyway, you probably know better than I do. |
2) thanks for ur doubting thing ("...turbulence would have any effect...... "), in fact the flow time is about 0.5 sec or less, i will think about the effect of gas from the begining. 3) Moldflow is the best pure injectoin solver, but it cannot satisfy me, and it's lack of flecibility. may i have your e-mail, i wanna consult something about solidification/melting molding~~~ thanks |
