April 23, 2012, 14:31 |
Boundary Definition
Sultan
I have a voxelized random packed of spheres. I have created mesh with Avizo. I can import the mesh; however, there is no inlet or outlet boundaries. I do not know how can I define the boundaries. I would appreciate if you could help me. Thanks...
April 23, 2012, 15:06 |
#2 | |
Lucky
Rep Power: 65 |
If you have all the boundary surfaces and they are correct, the only problem left is that they need to be assigned the correct boundary type. From GUI it is straightforward, on the boundary conditions menu. Select the boundary and change its type to the appropriate type inlet/outlet or whatever. From TUI use the \define. |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
