Along which direction is the lift coefficient |
April 22, 2012, 16:40 |
Rep Power: 14 |
Hi im doing a 2D CFD case for a NACA foil pitching and heaving. Was just wondering if the lift coefficient given by fluent is normal to the inlet flow or normal to the moving foil at that time instant. Thank you.
April 22, 2012, 19:32 |
Lucky
Rep Power: 65 |
The user inputs for Drag and Lift coefficient will ask you to input the force vector. The drag and lift coefficients are then calculated with respect to this inputted vector regardless of what the inflow conditions are.
April 23, 2012, 20:32 |
Rep Power: 14 |
Thank you for replying. So if i input to calculate lift for the foil, it will be normal to the foil and and not respect to the x and y velocities in the global coordinate at that instant. Hope this is what you mean.
April 23, 2012, 23:29 |
#4 | |
Lucky
Rep Power: 65 |
It does not care what the global x, y, or local surface normal is. |
cfd, fluent |
Display Modes | |
Lift coefficient in Eulerian multiphase model | hennas | FLUENT | 1 | July 4, 2011 17:50 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
Zero Coefficient of Lift Problem | MH | FLUENT | 0 | February 25, 2007 12:48 |
Lift force or coefficient of lift | Rola | FLUENT | 1 | November 12, 2006 14:29 |
drag and lift coefficient | Noé | Siemens | 5 | July 13, 2004 11:21 |
