April 30, 2012, 03:22 |
Coarsening a mesh using grid adaptation
I want to make my mesh coarser using grid adaptation. I cant do this when I go to register cells, click on coarse and then click Mark button, Fluent says
1234 number of cells for refinement 0 marked for coarsening. Why is it so ? Regards, |
May 1, 2012, 14:29 |
Lucky
Rep Power: 65 |
0 cells met your coarsening criteria that you specified.
May 2, 2012, 00:05 |
didn't get your point. I specified the range of cells for coarsening then it should merge two or more cells to make it coarse.
May 2, 2012, 00:26 |
Lucky
Rep Power: 65 |
exactly, you specified 1234 cells but that's not a criteria for marking which cells need refinement/coarsening. 0 cells were marked means exactly that, 0 cells were met the threshold value for grid adaption.
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
[Other] How to mesh the 1st grid point | lakeat | OpenFOAM Meshing & Mesh Conversion | 1 | October 8, 2007 07:13 |
