May 28, 2013, 10:49 |
Floating point error/ divergence problem
Yasir hayat
Rep Power: 12 |
Hi all,
I am simulating cryogenic boiling in fluid film bearings using Ansys fluent. My working fluid is liquid nitrogen. I tried the combination of 1)k-omega model sst, mixture model and energy equation; 2) k omega sst , eulerian model and energy equation. In both cases some where in the iteration divergence occurs and my maximum temperature in the working domain shoots up and i get floating point error any suggestions how to tackle this problem and any suggestions how to make a good boiling model. i have one an other question what exactly Back flow total temperature means in the boundary conditions ( pressure outlet ---> thermal tab ---> total back flow temperature). do we have to give some rough values ? does these values have some considerable effect on our solutions? same question goes for volume back flow fractions. Thanks and Best regards yasir hayat |
MPI Error - simpleFoam - Floating Point Exception | scott | OpenFOAM Running, Solving & CFD | 3 | April 13, 2012 16:34 |
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) | ArianeJasmin | OpenFOAM Programming & Development | 1 | April 4, 2012 14:11 |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 05:11 |
having a problem whit floating point error and it's solution | m.beh | FLUENT | 2 | November 9, 2010 10:28 |
floating point error when starting to iterate | Ralf Schmidt | FLUENT | 1 | June 2, 2006 06:00 |
