Help:Euler model with inmiscible fluid model
Need Help. (Fluent)
I'm using Euler model with inmiscible fluid model as multiphase model for modeling gas-liquid flow in tube, but when I calculating, of Courant Number is greater than 250 in the second iteration. The message is the following: Error. Globar courant number is greater than 250.00 The velocity field is probably diverging. Please check the solution and reduce the time-step if necessary. Error Objet: #f I tried the following: reduce the time-step, reduce the inlet velocity of both the phases, but did not work. Anyone knows how to setting model that does not happen?? I not using VOF model because it not fulfill my requirement. |
