May 10, 2012, 11:10 |
Opening boundary condition
Elias Paez
Rep Power: 14 |
Hi all,
My question is quite simple: Is there an "Opening" BC in Fluent like in CFX? Because, I usually use the "pressure_outlet" to achive this condition (gauge pressure=0), but I'm not really sure if it is a correct solution. Regards |
May 11, 2012, 02:21 |
Rep Power: 17 |
The Opening BC in CFX is also a pressure outlet BC. Only difference is that it allows a reversed flow and does not close off faces which encounter a reversed flow (like the pressure outlet BC does in CFX)
Regards Luke |
May 11, 2012, 06:18 |
Elias Paez
Rep Power: 14 |
Thanks Luke,
And, do you know if it exist a big difference between use pressure inlet or pressure outlet in this case?, because i saw people in the forum using pressure inlet, and i think it is not a good solution. |
May 11, 2012, 06:46 |
Rep Power: 17 |
In which case? What are you trying to analyse?
In most cases a pressure inlet with a pressure outlet is the most stable BC combo Regards Luke |
Boundary condition clarification | shaswat | CFX | 1 | April 8, 2012 04:06 |
Fluent Boundary Condition for Opening | rippert42 | FLUENT | 11 | November 9, 2011 12:06 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
CFX Solver : Sudden crash | Hervé | CFX | 2 | June 16, 2008 06:40 |
boundary condition set for opening | Hellen | Main CFD Forum | 7 | June 29, 2005 09:21 |
