Home > Forums > FLUENT
Boundary conditions/solver
Old   May 10, 2012, 00:23
Default Boundary conditions/solver
Christiane
chrisausAUS is on a distinguished road
Hi!
I have to simulate a screw extruder.
I have set up the geometry - I have an inlet and an outlet needle.
I have the inlet as one part, the screw fluid as one part and the needle part.
I meshed within ANSYS workbench. Named the inlet and outlet as well as the screw wall.
I set up: Using laminar flow, defining a new fluid (PCL) with values I found in the literature.
For the cell zone condition I put fluid everywhere. For the screw fluid body I also tick frame rotation with rotation around - y axis with a certain speed.
Boundary conditions: Inlet-pressure 7e5 Pa, outlet-pressure 0 Pa gauge pressure, screw_wall is rotating around - y axis with the same speed as the frame rotation.
Solver is Presto and second order upwind momentum.
Monitors is the convergence turned off.
Then I initialize.
And then run until stable around 4000 iteration steps.
PROBLEMS that I have:
1) it is stable, but in the 10^3 range rather than 10^-4 range.
2) I tried standard/ second as well as standard/first, but the problems remains.
3) I didn't rotate the frame. And the same thing happens (stabilized at around 10^3)
4) If I make the whole extruder out of one part, then I get stabilizing in the 10^-4 to 10^-16 range for standard/second. If I use presto - I get still 10^3 and oscillating like crazy.
That brought me to the thought, that something must be wrong with my parts and their connection maybe.
Please give me some suggestions what I can try out next.
Christiane
chrisausAUS is offline   Reply With Quote
Thread Tools
Trackbacks are On
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
