Sonic flow for exhaust nozzle
Old   May 10, 2012, 11:42
Default Sonic flow for exhaust nozzle
Choon Yee
beanlee999 is on a distinguished road
Hi all,
I am doing a simulation for an convergent exhaust nozzle.
Can anyone provide me with advice on what to look out for during initialisation, if my simulation is likely to give me a sonic flow at the nozzle exit?
I am doing a compressible, turbulent flow analysis, with the pressure inlet used for nozzle inlet, and pressure outlet as nozzle outlet.
My previous attempts to run this simulation have kind of failed. I believe the nozzle inlet pressure is high, probably leading to sonic flow occuring at the nozzle exit. However, i believe my initialisation variables are not suitable to give me a sonic flow condition at the nozzle exit plane. Therefore, my simulation leads to divergence or poor convergence.
thank you!
beanlee999 is offline   Reply With Quote
Old   May 10, 2012, 14:34
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
1. The sonic flow for exhaust nozzles generally develops at after the nozzle and in the atmospheric.
2. You should apply the static pressure at the outlet according to your pressure ratio calculation.
3. create the large enclosure (at-least 20 lengths of nozzle) at the outlet plane and provide static pressure at the outlet of this enclosure. In this way the flow at the nozzle exit develops in a more natural way.
4. This is my personnel experience.
Far is offline   Reply With Quote
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
super/sub sonic flows in laval nozzle Kalyan Siemens 4 August 17, 2005 17:58
Compressible flow in nozzle rawin FLUENT 7 January 19, 2005 07:33
NEED HELP! Flow through nozzle vanes with clerance C K Tang Fidelity CFD 2 July 29, 2003 13:07
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
