-   -   Diesel injection problem (http://www.cfd-online.com/Forums/fluent/101902-diesel-injection-problem.html)
Jurek May 16, 2012 14:44
Hi all,
i want to ask you for an advice for my problem with direct injection.
I have problem with setting injection. In fact i have injector with five nozzles with diameters 0.36 mm. Flow rate through one nozzle is 0.004 kg/s. Injection time is about 0,002758 s. Required value of injected fuel in chamber is approximately 2,535e-5 kg. I simulate for each nozzle new injection with different direction. My problem is that after injection when i click on reports - summary - all injections (5) i get a summary for injections and there total mass.
And this mass is about one order smaller as i need. I used this parameters:
injection type-solid-cone, number of particle streams-i dont know how many, because o dont know what does it mean, particle type-droplet, material - n-heptan. X,Y,Z positon-clear, diameter -??(0,36)??, temp-320K, start CA-336, stop CA-358, X,Y,Z axis-clear, velocity magnitude -???, cone angle - 5, radius - ??, total flow rate - 0,004.
For any advice thank you.
Jurek
juraj.saniga@yahoo.com
